PINGIU987
Jan 05, 2019Aspirant
xr500 problemi in game
dopo una partita che gioco va bene ma dalla seconda in poi mi crasha in game dopo continua a darmelo e sena risultati se si può fare qualcosa
Jan 08, 2019Guru - Experienced User
Who is your Internet Service Provider and is there a modem or separate internet service unit device that your ISP installed that gives you internet to the XR router? We need the manufacture and model# of this modem unit that your ISP may have installed.
This is not the NetGear XR router.
- PINGIU987Jan 08, 2019Aspirant
tim smart modem
- Netduma-FraserJan 08, 2019NetDuma PartnerWhat game are you playing? Are you using the Geo-Filter? Are the disconnects just from the game or the internet also?
destiny 2 yes use geo - filter no solo game
- FURRYe38Jan 09, 2019Guru - Experienced User
Is this your ISP modem?
If so, then you already have a router online infront of the XR router.
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the NG router gets from the modem.
PINGIU987 wrote:
tim smart modem
- Netduma-FraserJan 09, 2019NetDuma PartnerI think I understand what is happening, you need to have strict mode disabled for Destiny. You can untick this in the Geo-Filter Map options, I would also suggest using the Destiny profile available on the Geo-Filter.
