Hickery1995
Sep 29, 2018Aspirant
XR500 Problems! Help
Hi, I bought my Nighthawk XR500 router yesterday, my first gaming router, anyway i've came home and set it up and seem to have some problems, all devices have connected spot on, other than my xbox, or...
Hickery1995
Hi and thankyou for your reply, I've just done a factory reset, previously i had my geofilter set to the uk but it was showing me a triangle somewhere in the states and it was as if my device (Xbox one) kept trying to connect to that, so im going to attempt again now, also when i run an ethernet cable from my XR500 to the xbox, i get no internet, any idea why? (Wi fi connects fine) thankyou.
Netduma_Jack
Sep 29, 2018NetDuma Partner
Ok, let us know how you get on. The Geo-Filter has a default start location of California, so you will need to move it to begin.
The most likely reason wired is not working is because you have a static IP set on your Xbox for LAN connections. If you go to Network Settings you should be able to set this to dynamic.
If it's not that, then try a different Ethernet cable as you could have a dodgy one.
- Hickery1995Sep 29, 2018AspirantHi again Jack, thanks for the reply, ive moved the geo filter to my location now, my ping is still worse than what it was before i bought this new router, also i keep getting double nat on strict, i have no bridge mode or modem mode on my modem/router at home (the one the xr500 is wires up to) any ideas,as for the ethernet cable i will try that shortly
- Netduma_JackSep 30, 2018NetDuma PartnerDo you have a DMZ option on your modem? If you do, you want to put your XR500 in your modem’s DMZ. Let me know if you’re not sure how to do this.
How are you measuring your ping?- Hickery1995Oct 01, 2018AspirantHi, im not really sure how to setup a DMZ or what it means, so help would be great. My XR500 is connected up to a talk talk hg633 router, which has no modem mode or bridge mode. I have turned the wifi off on my talk talk router to stop any confusion between the 2 routers, but have no idea about dmz, should this help the connectioj improve? And im measuring my ping on fortnite, im not sure how to check my ping using the xr500 website.
