Hickery1995
Sep 29, 2018Aspirant
XR500 Problems! Help
Hi, I bought my Nighthawk XR500 router yesterday, my first gaming router, anyway i've came home and set it up and seem to have some problems, all devices have connected spot on, other than my xbox, or...
ericmartinez23
Dec 14, 2018Aspirant
Hi not really that tech savy live a 5 year old really need to be watched. i just bought the XR500 nighthawk for my kids to game and leave my firstike to me and wifey. but i can't get their Xboxes to connect to the 5G portion of the router that is the whole reason for buying this router. can some one please help me with this so i can help my kids thank you..
Netduma-Fraser
Dec 15, 2018NetDuma Partner
Hi Eric, first of all I would always recommend you have the consoles connected via ethernet but if you have to use WiFi then I would always recommend using 2.4GHz. Also depending on which version of the Xboxes you have they may not support 5GHz. You may have the XR500 using Smart Connect which means there is only one WiFi network and it will switch between 2.4GHz and 5GHz depending on individual devices needs so you could disable this then try to connect manually.
- ericmartinez23Dec 15, 2018Aspirant
It will not even connect to the 5G and they have Xbox1
- Netduma-FraserDec 15, 2018NetDuma PartnerWhat actually happens when you try to connect it? Did you disable Smart Connect so theres a separate WiFi name for it?
Yes i did when we first got it but it will not let anything but my laptop connect ?
