Piterpx
Jul 08, 2022Aspirant
XR500 Problems VOIP with geofilter in PC
Hello. When I put the geofilter, I have problems with the VOIP in the games, especially in the Hunt Showdown that blocks it completely. Any help to fix it? THANKS
Piterpx
Sorry. I change it now
Jul 08, 2022Guru - Experienced User
What gaming platform are you using? PC or console?
Does this happen with other games as well?
- PiterpxJul 08, 2022AspirantFirmware: 2.3.2.134
The isp router and ont is the default of ADAMO in spain. I have the conexion for bridge port to NT router. I used PC for gaming- Netduma-FraserJul 08, 2022NetDuma PartnerWe haven't tested that specific game so couldn't say whether it can filter it optimally but you'll need to add your friends to the allow list to hear them when the Geo-Filter is used. You can see how to do this at the bottom of this guide: http://support.netduma.com/en/support/solutions/articles/16000077072-dumaos-optimal-settings-guide-geo-filter
- PiterpxJul 10, 2022Aspirant
Hello. I try this solution but it does not work. Another solution?
