Piterpx
Jul 08, 2022Aspirant
XR500 Problems VOIP with geofilter in PC
Hello. When I put the geofilter, I have problems with the VOIP in the games, especially in the Hunt Showdown that blocks it completely. Any help to fix it? THANKS
Piterpx
Firmware: 2.3.2.134
The isp router and ont is the default of ADAMO in spain. I have the conexion for bridge port to NT router. I used PC for gaming
Netduma-Fraser
Jul 08, 2022NetDuma Partner
We haven't tested that specific game so couldn't say whether it can filter it optimally but you'll need to add your friends to the allow list to hear them when the Geo-Filter is used. You can see how to do this at the bottom of this guide: http://support.netduma.com/en/support/solutions/articles/16000077072-dumaos-optimal-settings-guide-geo-filter
- PiterpxJul 10, 2022Aspirant
Hello. I try this solution but it does not work. Another solution?
- Netduma-LiamJul 11, 2022NetDuma Partner
What about this didn't work?
Did you see 'blocked' icons appearing on the Geo-filter map when your friends were joining you? You may need to zoom all the way out on the map, these icons can sometimes appear to be connecting from much further away.
- PiterpxJul 11, 2022Aspirant
The problem is that I play with random people and the enemies also have VOIP and I can't hear any of them
