Piterpx
Jul 08, 2022Aspirant
XR500 Problems VOIP with geofilter in PC
Hello. When I put the geofilter, I have problems with the VOIP in the games, especially in the Hunt Showdown that blocks it completely. Any help to fix it? THANKS
Piterpx
Jul 11, 2022Aspirant
The problem is that I play with random people and the enemies also have VOIP and I can't hear any of them
Netduma-Fraser
Jul 11, 2022NetDuma Partner
You won't be able to counteract that because it would block them, best thing to do would be to get a game using the Geo-Filter and then disable it so you can hear VOIP
