JonSnowKnowsNad
Dec 11, 2019Apprentice
XR500 PS4 Party Chat not working unless I reboot my router
On the latest firmare for my XR500 and i've had a couple of issues. I've disconnected from the internet randomly and PS4 party chat does not work unless I reboot my router. Also the DumaOS on the des...
Netduma-Fraser
Dec 11, 2019NetDuma Partner
Is there any difference between accessing it via the LAN IP or routerlogin.net? Are you typing HTTPS at the beginning of the URL?
JonSnowKnowsNad
Alright I got it to work on google chrome. I deleted all my browser history, cache, cookies and allowed the site to save cookies. It worked. Thank you so much bro!!!! I'll let you know if i run into some extra problems.
- JonSnowKnowsNadDec 12, 2019Apprentice
I just learned why I randomly disconnect from the internet. Cause of DDOS attacks. How do i protect myself from DDOS attacks?
- Netduma_AlexDec 13, 2019NetDuma Partner
Are you seeing this in the router logs? The router logs use the phrase "dos attack" a lot which sounds a lot more dramatic than it should and isn't actually anything to worry about.
- JonSnowKnowsNadDec 13, 2019Apprentice
Yeah i see DOS attack in the logs. If it isn't anything to worry about then alright bro.
I can't hear my teammates in party chat even when I put them in the allowed list. some of them are outside my geo-filter circle. It shows a triangle around them.
- Netduma-FraserDec 14, 2019NetDuma PartnerJust to reiterate those entries are nothing to worry about as Alex has said. I've responded to the new topic you created about the party chat issue.
