andysiow85
Jul 02, 2020Guide
XR500 Ps4 party chat
Hi, I have been using this router for about 2 month now. In love with all the functions of the router especially the Geofilter. Also the main reason I chose this router is because of the geofilter. ...
andysiow85
Jul 04, 2020Guide
Hi Fraser,
Thank you for your reply.
ISP modem is connected to a ethernet box (living room) and my router is connected to the wall ethernet in my room. PS4 is connected wired to router directly.
Netduma-Fraser
Jul 04, 2020NetDuma Partner
It sounds as though you're using the XR exclusively while others in the home are using the ISP router is that right? There may be some port conflicts going on there, have you put your XR500 in the DMZ of the ISP router? It would be best for QoS if all devices were connected to the XR as well.
