chiefsoap
Sep 28, 2018Guide
XR500, PS4 Pro, Ethernet, and ESO
 This can very well be an ESO (Elder Scrolls Online) problem and their potato servers but sometimes I feel like it's a router issue because my wife and I will disconnect around the same time while oth...
Netduma_Jack
Sep 28, 2018NetDuma Partner
Hi there,
A couple of questions to help find the problem:
- Can you make sure you have installed the latest firmware as older firmware did cause some disconnections for some users: https://www.netgear.com/support/product/XR500.aspx#Firmware%20Version%202.3.2.32
 - Does your entire network go down when you have the drops? Or is just the PS4 pro. For example, if you use your phone on WiFi at the time the game drops out, do you still have Internet on the WiFi?
Thanks.
chiefsoap
Sep 28, 2018Guide
Netduma_Jack wrote:
Hi there,
 Thanks.
1. I believe so, is this separate from the OTA update I was prompted to apply a week or so ago?
2. No it does't. Both playstations go down about the same time. I'm able to surf the web on my phone and what not
- XRaptor29Sep 28, 2018LuminaryMaybe a PlayStation Network issue or Google fiber?
My wife and I are on Xbox and don't have this issue, the most we face is a lot of lag from loading into heavily populated areas.
Are you by chance still using the Google Fiber router they provide and is it set to bridge mode? Also try reserving the console IP addresses on the XR500.- chiefsoapSep 28, 2018Guide
Are you by chance still using the Google Fiber router they provide and is it set to bridge mode? Also try reserving the console IP addresses on the XR500.Yes I am still using the Google Fiber box and its essentially set to bridge mode. Their modems/routers don't have a true bridge mode, best I can do is assign the router a static IP, add it to DMZ, and disable WiFi on the Google box.
- XRaptor29Sep 28, 2018LuminaryAre the PS4's hardwired? I've heard multiple consoles over wifi a lot of routers struggle with port management.
