chiefsoap
Sep 28, 2018Guide
XR500, PS4 Pro, Ethernet, and ESO
This can very well be an ESO (Elder Scrolls Online) problem and their potato servers but sometimes I feel like it's a router issue because my wife and I will disconnect around the same time while oth...
chiefsoap
Sep 28, 2018Guide
Netduma_Jack wrote:
Hi there,
A couple of questions to help find the problem:
- Can you make sure you have installed the latest firmware as older firmware did cause some disconnections for some users: https://www.netgear.com/support/product/XR500.aspx#Firmware%20Version%202.3.2.32
- Does your entire network go down when you have the drops? Or is just the PS4 pro. For example, if you use your phone on WiFi at the time the game drops out, do you still have Internet on the WiFi?
Thanks.
1. I believe so, is this separate from the OTA update I was prompted to apply a week or so ago?
2. No it does't. Both playstations go down about the same time. I'm able to surf the web on my phone and what not
XRaptor29
Sep 28, 2018Luminary
Maybe a PlayStation Network issue or Google fiber?
My wife and I are on Xbox and don't have this issue, the most we face is a lot of lag from loading into heavily populated areas.
Are you by chance still using the Google Fiber router they provide and is it set to bridge mode? Also try reserving the console IP addresses on the XR500.
