chiefsoap
Sep 28, 2018Guide
XR500, PS4 Pro, Ethernet, and ESO
This can very well be an ESO (Elder Scrolls Online) problem and their potato servers but sometimes I feel like it's a router issue because my wife and I will disconnect around the same time while oth...
XRaptor29
Sep 28, 2018Luminary
Maybe a PlayStation Network issue or Google fiber?
My wife and I are on Xbox and don't have this issue, the most we face is a lot of lag from loading into heavily populated areas.
Are you by chance still using the Google Fiber router they provide and is it set to bridge mode? Also try reserving the console IP addresses on the XR500.
chiefsoap
Sep 28, 2018Guide
Yes I am still using the Google Fiber box and its essentially set to bridge mode. Their modems/routers don't have a true bridge mode, best I can do is assign the router a static IP, add it to DMZ, and disable WiFi on the Google box.
- XRaptor29Sep 28, 2018LuminaryAre the PS4's hardwired? I've heard multiple consoles over wifi a lot of routers struggle with port management.
- chiefsoapSep 28, 2018Guide
XRaptor29 wrote:
Are the PS4's hardwired? I've heard multiple consoles over wifi a lot of routers struggle with port management.Yes its hard wired, CAT6
- XRaptor29Sep 29, 2018LuminaryHave you tried putting both consoles in spectating mode in Geo-filter. Zenimax has the ESO servers sitting in Dallas, TX and depending how large you have your Geo Filter radius it might be cutting out where the servers are.
