chiefsoap
Sep 28, 2018Guide
XR500, PS4 Pro, Ethernet, and ESO
This can very well be an ESO (Elder Scrolls Online) problem and their potato servers but sometimes I feel like it's a router issue because my wife and I will disconnect around the same time while oth...
XRaptor29
Sep 28, 2018Luminary
Are the PS4's hardwired? I've heard multiple consoles over wifi a lot of routers struggle with port management.
chiefsoap
Sep 28, 2018Guide
Yes its hard wired, CAT6
- XRaptor29Sep 29, 2018LuminaryHave you tried putting both consoles in spectating mode in Geo-filter. Zenimax has the ESO servers sitting in Dallas, TX and depending how large you have your Geo Filter radius it might be cutting out where the servers are.
- Netduma_JackSep 29, 2018NetDuma Partner
That's a good question from Raptor - do you have your Geo-filter enabled in Filtering Mode? I assume not, but if so this could be a problem. You don't really need it in filtering mode for a game like ESO, so i'd recommend putting it to Spectating Mode.
However, I suspect that's unlikely to be the problem. It would be good to isolate the problem, to see if it's 100% the XR500 or something else.
The simplest way of doing this would be to play for some time on your modem, and then play for some time on your XR500. Then see if either drops out.
- chiefsoapSep 29, 2018GuideI’m going to give spectating mode a shot and see how well it works out.
- Netduma_JackSep 30, 2018NetDuma PartnerGreat, thanks for the update. Hope it works.
