chiefsoap
Sep 28, 2018Guide
XR500, PS4 Pro, Ethernet, and ESO
This can very well be an ESO (Elder Scrolls Online) problem and their potato servers but sometimes I feel like it's a router issue because my wife and I will disconnect around the same time while oth...
XRaptor29
Sep 29, 2018Luminary
Have you tried putting both consoles in spectating mode in Geo-filter. Zenimax has the ESO servers sitting in Dallas, TX and depending how large you have your Geo Filter radius it might be cutting out where the servers are.
chiefsoap
Sep 29, 2018Guide
I’m going to give spectating mode a shot and see how well it works out.
- Netduma_JackSep 30, 2018NetDuma PartnerGreat, thanks for the update. Hope it works.
- chiefsoapOct 02, 2018Guide
Netduma_Jack wrote:
Great, thanks for the update. Hope it works.Just an update -
It happened again last night with the router. Major fight w/ 50+ people happened and is disconnected from servers.
I'm connecting directly to the Google Fiber Router/Modem tonight to see if I yeild the same results.
- Netduma-FraserOct 02, 2018NetDuma PartnerHi chief, its definitely a good idea to keep the Geo-Filter in Spectating Mode. I imagine the game has it's own servers that you can select even though it's on consoles as most RPGs do, is that the case? If so I would make sure you're selecting the closest server to you. If they do show servers do they by any chance show a load %? If so pick one that is quite low, that should rule out if it's the server itself becoming overloaded and point to a different issue rather than the game.
Do both consoles give NAT Type 2 on the PlayStation network test when connected to the XR500? I would suggest giving the XR500 a static IP on the Google Fiber router, disabling WiFi and putting the XR500 in it's DMZ if you suggested to see if it's an issue with the partial bridge mode option they have.
Are you utilising Traffic Prioritization on QoS? (You should be as DumaOS Classified Games is enabled by default) If not, enable this and see if that resolves the issue. It places your gaming packets ahead of any network queues that may be happening. If you are using it try disabling it and see if that resolves the issue.
Does it always appear to happen when there is a lot happening on the game or have you noticed it happening at other times? - chiefsoapOct 03, 2018Guide
So just an update. Last night I went straight through the Google Box and I had issues getting disconnected, my spouse didn't. She went the entire night without any disconnects. Same scenario. The only major difference between the Google Box and XR500 is when I was using the XR500, disconnects were happening to both of us almost simutaiously.
When I swapped the XR500 for the Google box, I had to swap 1 ethernet cable that connected the modem to the fiber box in the house in order for it to reach both consoles. I'm going to try replacing that ethernet cable tonight and see how it works out.
Does it always appear to happen when there is a lot happening on the game or have you noticed it happening at other times?A couple of nights ago when I was testing using the router it put in spectating mode and it didn't make a difference. Unfortunately when the game starts up I only have the option of selecting US Mega Server or EU Mega Server. However; I had tried changing my DNS to Google Public and tonight I'm going to test using Open DNS to see if that makes a difference. Fwiw - the my spouses PS4 has been using Google Public DNS the entire time. Both consoles give NAT Type 2. Both consoles have a static IP and I've already configured the Google Box using the instructions above of putting the router in Google Fiber's "bridge mode".
I am using utilizing traffic prioritization in QoS and I have it bumped up pretty high for both consoles, I'm fairly certain Duma OS Classified Games is enable but I'll need to double check.Disconnects occur during open world pvp (when there's like 50+ people on the screen at once) and I get pretty awesome lag spikes during raid events (12 people on the screen) when they are alot of particle effects and generally a lot going on. The pattern is absolutely isolated to those type of scenarios. No other scenario do the lag spikes and disconnects occur
- Netduma_JackOct 03, 2018NetDuma Partner
Thanks for the update Soap. If you are getting disconnects when connected into the modem, that points to the cause being either in the modem, the cabling or the line itself? Let me know if you think I'm wrong.
As for NAT Type 2 - that generally should mean everything is still fine, but obviously type 1 is preferred. It might be worth taking the modem back out of bridge mode and instead seeing if there is an option for DMZ, where you then put the XR500's IP address into the IP (this is the IP address according to your modem, also known as the XR500's WAN IP)
Let us know how you get on.
- chiefsoapOct 07, 2018Guide
Another update on the on-going saga - Saturday Morning Google Fiber came out and not only replaced their modem but also checked everything. According to them, everything is all good. So today I've reconnected the XR500 and I'll resume operations. I'll keep everyone up to date on what's going on
- Netduma_JackOct 07, 2018NetDuma PartnerGreat, thanks for letting us know. Hope it works out well.
