Kinag
Mar 27, 2020Aspirant
XR500 QoS causing trouble with Samsung tv
Hi, I have an issue which I've finally figured out is caused by the QoS. Whenever I have QoS applied on my router my TV refuses to stream videos from several apps. I got a Samsung Q7FN TV, but this ...
Netduma-Fraser
Apr 01, 2020NetDuma Partner
My reason being, the guest wifi may not work the same with QoS as the normal devices and so may be able to bypass the restriction while allowing all your devices to benefit from QoS. So it doesn't work even when connected to the Orbi?
Kinag
Apr 01, 2020Aspirant
That is correct.
Neither with Orbi in AP mode, through cable to the XR500 or through normal wireless through the XR500.
- Netduma-FraserApr 01, 2020NetDuma PartnerIn WAN Settings could you untick IGMP Proxying please and see if that helps. Otherwise I'll have to pass it onto the team.
- KinagApr 01, 2020AspirantI already have, I saw it was proposed in another thread. It had no effect unfortunatly. I hope this is something that can be looked at rather quickly.
It should be interesting for the developers to look into as well I guess (speaking as an IT Technician). - Netduma-FraserApr 01, 2020NetDuma PartnerI've passed it on to the devs so hopefully they'll have some insight.
