Agentwhite
Jun 26, 2022Star
XR500 QoS device not found error after factory reset
I randomly started having problems with my XR500 where it would just keep rebooting itself. I tried a factory reset which so far has solved the rebooting issue, however now when I got to the QoS tab ...
- Jun 26, 2022
For anyone else finding this, I was able to solve the problem by downloading the DumaOS app on iOS. From the app I could load everything fine, I then deleted the devices defined in the traffic prioritization widget. Then went back to PC browser, everything loaded fine and I could re-add my devices.
Kevin1199
Jul 23, 2022Guide
How would you even download any app to iphone if the XR500 does not have a Duma app.
Agentwhite
Jul 23, 2022Star
- Netduma-FraserJul 24, 2022NetDuma PartnerAs above, that is the official mobile app from us!
- boricuajr84Aug 06, 2022Aspirant
how do you log into this app for Android? Same log in from Routerlogin.net?
- Netduma-FraserAug 06, 2022NetDuma PartnerSo search DumaOS on the Google Play Store and then login using the same credentials you would use to access the interface on a PC
