David84
May 31, 2021Aspirant
XR500 QoS error: device not found
Hello. I updated my xr500 router with firmware V2.3.2.144, I reset it and after setting everything in Qos a popup comes out with this "error: device not found". I tried to install other firmware, new...
Netduma-Fraser
Jun 01, 2021NetDuma Partner
Downgrade to a previous firmware, do a factory reset from the interface, then re-upgrade again please and it should be working
- David84Jun 01, 2021Aspirant
I had already tried but it doesn't work.
luckily I just solved it like this:
factory reset
firmware installation .114
factory reset
I turned on all devices (including ps5)
router setup wizard.now it works correctly.
Maybe it gave an error because the ps5 console was not turned on at the time of reset?
- Netduma-FraserJun 01, 2021NetDuma PartnerYes that's possible, glad to hear you got it sorted, thanks for posting the solution!
