David84
May 31, 2021Aspirant
XR500 QoS error: device not found
Hello. I updated my xr500 router with firmware V2.3.2.144, I reset it and after setting everything in Qos a popup comes out with this "error: device not found". I tried to install other firmware, new...
David84
Jun 01, 2021Aspirant
I had already tried but it doesn't work.
luckily I just solved it like this:
factory reset
firmware installation .114
factory reset
I turned on all devices (including ps5)
router setup wizard.
now it works correctly.
Maybe it gave an error because the ps5 console was not turned on at the time of reset?
Netduma-Fraser
Jun 01, 2021NetDuma Partner
Yes that's possible, glad to hear you got it sorted, thanks for posting the solution!
