Jman40916's avatar
Jman40916
XR500 QOS issue
Hello,
Thank you in advance for any help or responses.
I have not been able to find the exact issue I am experiencing on the forums or here. I am trying to set up the QOS for my Xbox specifically for Overwatch 2, but after setting it up it does not "activate" I left it like this for hours reset my router multiple times, and reset the settings. The Duma OS games detects that I am gaming when I have that active, but it never detects when I set up my Xbox specifically with Overwatch 2.
I have verified that the IP is correct and that there are no interfering IPs. It is plugged in via Ethernet straight to the router and I have tried different ports as well. Is this just an Overwatch 2 issue on DumaOS?
Let me know if I can be more specific. Thanks.
  • For consoles you add it with the Games Console service, you don't choose the specific game for consoles, that's for PC. Also if DumaOS Classified Games is prioritizing it then it'll be working.
    • Jman40916's avatar
      Jman40916
      That makes sense. Thank you.
      My next issue is that when I am gaming the network monitor shows that gaming is not being used, but the "unrecognized" is being used the most.
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        We'll be pushing a new cloud update to the XR range soon which should resolve that
