TurtleBird
Jan 15, 2019Aspirant
XR500 QoS Not Working
I am having an issue with my XR500 that I am hoping this forum can help solve.
Occassionally (a few times a day), Outlook running on my Mac spikes to 10-15 Mbps upload. When this happens, it b...
Netduma-Fraser
Jan 15, 2019NetDuma Partner
Are you using Anti-Bufferbloat? As it's perfect for preventing spikes like those affecting your network. Suggest you set it to 'Always' and 70% for both download/upload and see if that resolves your issue.
TurtleBird
Jan 17, 2019Aspirant
Thanks for the recommendation. I tried this, and it seemed to help (Outlook only spiked to 5 Mbps) but it didn't totally fix the problem, my voice still was choppy in Discord. Would it make sense to decrease past 70%?
Thanks!
- FURRYe38Jan 17, 2019Guru - Experienced User
What happens with the setting at 80% then try 90%.
Thanks!
- TurtleBirdJan 17, 2019Aspirant
Wouldn't increasing to 80% or 90% decrease the effectiveness of antibuffer bloat (ie would allow additional bandwidth to be consumed by Outlook)?
Outlook doesn't need much.
What are you doing with Outlook?
