Huthayfa
Jul 16, 2018Guide
XR500 QoS, UPnP issue with VLAN tagging.
Hi,
recently I have got my XR500 with DumaOS. I discovered an issue, I am using fiber connection that requires VLAN tagging on WAN to get the internet working. when I put my fiber ONT in full brid...
- Aug 30, 2018
this issue has not been fixed yet, and guess what? seems like there is no fix at all.
for everyone else having VLAN setup, be careful while cosndering the XR500 for your setup since you will find some main feaures not working properly.
thanks.
Huthayfa
Jul 16, 2018Guide
I have just received a response from Mr. Fraser, that they will work on the issue, hope this get fixed as soon as possible, thanks to everybody.
- HuthayfaJul 22, 2018Guide
Hi everyone,
I am still on waiting for the fix, no update from Netduma or Netgear support until now.
thanks
- Netduma-FraserJul 22, 2018NetDuma PartnerA fix takes time, certainly more than 4 days due to testing as well. I don't know the current status as Netgear will be dealing with it, once the new update is released check whether it has been implemented. Can also ask on your ticket for an update
thank you Mr. Fraser.
I will wait, just want to make sure that fix will be available soon.4-7 days is not an issue.
