jebrown1979
Aug 07, 2019Guide
xr500 qos
hi i am still new and learning all this stuff about this router now to get an accurate read for qos do i stick in my expected speeds from my isp or do i run several speedtests to get more of an accur...
Netduma-Fraser
Aug 07, 2019NetDuma Partner
Firstly I would recommend reading our optimal settings guides and that will allow you to get a handle on how the router works: http://support.netduma.com/en/support/solutions/folders/16000090646
It would be better to do tests direct from the modem when nothing is using the internet and use the average results you get from that. That's really down to you, if when not gaming devices still cause you to have buffering etc when streaming/watching videos online then choose always, otherwise when high priority traffic detected should be fine. No need to allocate bandwidth as it should get enough without doing that. If you read through the guides that should get you optimally setup.
