Laryke
Oct 26, 2021Apprentice
Xr500 quantum fiber
Hello, I move from xfinity cable to quantum fiber I want to only use my router (xr500), without their modem. I try doing it today but it didn’t work, the internet light was red. I put the Pppoe in int...
- Oct 27, 2021You'll need to connect the XR to that to get internet then. Copy the WAN IP from the System Information page on the XR router and enter it into the DMZ on the C4000 and you should be good to go. You can see how to do it here: https://www.centurylink.com/home/help/internet/modems-and-routers/advanced-setup/dmz-hosting.html
Laryke
Oct 27, 2021Apprentice
C4000xg
Netduma-Fraser
Oct 27, 2021NetDuma Partner
- LarykeOct 27, 2021ApprenticeYea, I will do that, but I was asking how I put my router without modem, because I read on the internet that can I have only my router connected to the internet if I have fiber
- Netduma-FraserOct 27, 2021NetDuma PartnerDoes the C4 work without a modem? If so check the exact settings that is using for the internet and then you may be able to apply it on the XR
