leob77
Dec 27, 2021Aspirant
xr500 question
Do I have to disable my modems wifi?
For what?
What are you trying to do?
If you're using the modem's (probably a combo device) wifi, you should have put the xr500 into the modem's DMZ if you want to continue to use it.
If that's not what you mean, a little more detail on what you're attempting and what issues you're running into would be beneficial.
- leob77Aspirant
Every device seems to work fine with the xr500 wifi execpt for my brothers pc which seems to connect to the original modem via wifi perfectly fine but on the xr500 he gets no internet with a wifi ip configuation is invalid error
do you have the XR500's IP address set in the att devices DMZ?
