Agentwhite
Apr 14, 2021Star
XR500 R apps stop working 24 hours after a router reboot
I'm running firmware v2.3.2.66 and my R apps all throw the same error message: Error: This R-App is not loaded yet, please try again in a minute. If I reboot the router, they will load and work for ...
michaelkenward
Apr 15, 2021Guru - Experienced User
What feeds the router? A modem of some sort? If so, the make and model might be useful information.
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so you might get responses here, but you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
Nighthawk Pro Gaming Routers - NETGEAR Communities
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
You may have done this already. I can't tell from your message.
