Agentwhite
Apr 14, 2021Star
XR500 R apps stop working 24 hours after a router reboot
I'm running firmware v2.3.2.66 and my R apps all throw the same error message: Error: This R-App is not loaded yet, please try again in a minute. If I reboot the router, they will load and work for ...
Netduma-Fraser
Apr 15, 2021NetDuma Partner
On the System Information page in the Rapp panel options change the retries to 5 then reboot the router from the interface and see if it lasts longer then
Agentwhite
Apr 15, 2021Star
It was already and has always been set to a value of 5. Either it came like that from factory or I set it a long time ago. Either way, I don't think that helps since the value has been 5.
- Netduma-LiamApr 16, 2021NetDuma Partner
This is a known issue that we're working on, you could try upgrading to the latest beta version here:
We'd suggest factory resetting after upgrading, see if that helps.
