PBandJ
Apr 19, 2018Guide
XR500 Random Reboot multiple times a day
XR500 with firmware 2.2.1.10 runs great when it runs, but reboots at random times. My kids are pissed their homework keeps getting interrupted. After updating to the latest firmware, did the fact...
- Apr 23, 2018
Well, the router worked for 36 hours then went back to multiple random reboots a day.
Turns out the data capture tech support wanted me to do gets wiped out on router reboot, so that was a waste.
I don't have time to deal with this. I'm back to my old router that is a little slow but at least gives me a reliable internet connection.
And the huge disappointment XR500 is on the UPS truck returned to the seller.
Netduma-Fraser
Apr 19, 2018NetDuma Partner
Totally understand the frustration, do let us know what support advise.
PBandJ
Apr 19, 2018Guide
Contacted support and have a case #. Thankfully they quickly bumped me up to level 2 support.
Now capturing logs to forward to engineering. Told it could take 5-6 days for them to address. :smileysad:
I thought it was ridiculous when they mentioned that my power outlet could be the issue. You mean the one that works perfectly well with my notebook, network switch and old router?
- Netduma-FraserApr 19, 2018NetDuma PartnerGreat to hear you're getting a good level of support. Though it will take some days hopefully using the information you provided the issue can get fixed! Please do keep us updated.
- JasonNApr 20, 2018NETGEAR Employee Retired
Hi PBandJ,
I'm glad that your are getting support on this and it is moving forward.
Please let us know what the resolution is. :]
- Jason N
- PBandJApr 20, 2018Guide
So far the router has been up close to 24 hours straight. The longest yet.
The only thing we did is start a continuous LAN/WAN packet capture in debug mode.Maybe the router senses it is being bad and could be sent back to be disassembled, so it is now behaving. haha.
Haha Thanks for the update PBandJ! Please let us know if anything else comes up. :]
- Jason N
