sev7nflow
Aug 04, 2022Apprentice
XR500 randomly drops internet throughout the day
Hello, My nighthawk netgear xr500 router keeps randomly dropping connection and all the lights turn off throughout the day. The only thing that fixes it is if I reset the power on the router. I looke...
Netduma-Fraser
Aug 04, 2022NetDuma Partner
In LAN Settings, set the DHCP range to start at .50, then assign reserved IP addresses to devices between .2 & .49 so they're out of the DHCP range, apply, reboot from the interface, wait 2 minutes and see if that stops the disconnects.
sev7nflow
i think i've done this correctly - see screenshot. I am still getting random router drops where all lights suddenly turn off. The power stays on and internet glows orange
- Netduma-LiamAug 05, 2022NetDuma Partner
Unfortunately we can't see that screenshot as it's not been moderated yet. Could you perhaps attach the screenshot instead of pasting it in.
- sev7nflowAug 05, 2022Apprentice
sure here you go
That looks good, do you only have three devices connected to the XR? If not, you may actually need to reserve IPs for every device on the network in order to prevent these crashes.
