Tsume
Nov 20, 2019Tutor
XR500 randomly loses connection
Just noticed that my complimentary support expired a few days ago (I didn't expected to be only 2 months) - anyway, my XR500 randomly loses connection every so and then. The solution is to unplug...
Nov 21, 2019Guru - Experienced User
Tsume wrote:Just noticed that my complimentary support expired a few days ago (I didn't expected to be only 2 months) - anyway, my XR500 randomly loses connection every so and then.
The solution is to unplug it from a wall socket, wait for a minute and plug it back in. It will work for a few days like a charm and then it will happen again. This seem to happen in the evening (no settings seems to cause that).
I can access routerlogin.net but I cannot access my modem on 192.168.0.1 when this occurs. I've tried connecting to the internet via ethernet cable and internet works. So it is something between router and the modem (switched the cable with another one, same thing).
When I switched the cable with another one, WIFI internet briefly started to work again, but after two or three minutes it lost all connection again.
These are stats of my XR500:
Firmware Version V2.3.2.56
DumaOS Name A7Legit
Modem does not regain the connectivity unless unplugged and plugged in again (I have left modem once up and runninig after it lost connection in the evening through the whole night and there was no internet in the morning).
I bought this router 2 or so months back. I would like to hear some advice :s
While everything else works, this one is annoying yet because it happens exactly when it shouldn't (when there's an action :( )
