Tsume
Nov 20, 2019Tutor
XR500 randomly loses connection
Just noticed that my complimentary support expired a few days ago (I didn't expected to be only 2 months) - anyway, my XR500 randomly loses connection every so and then. The solution is to unplug...
Netduma_Alex
Nov 21, 2019NetDuma Partner
As you say, it sounds like an issue between the modem and the router. I think you need to set a static/reserved IP for the XR500 on the modem. Do you know how to do this?
Tsume
Nov 21, 2019Tutor
I've made XR500 modem ip and mac reserved on my ISP modem. Hopefully that fixes the issue :)
For the question above about ISP modem:
Manufacturer Sky
Model SR102
Firmware Version 2.92.2508.R
DSL Firmware Version A2pv6F039m1.d24m
- FURRYe38Nov 21, 2019Guru - Experienced User
Your modem already has a built in router. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem.- TsumeNov 21, 2019Tutor
Yeah it has. Sky in the UK in general make customers life hell if they want to use anything else that they provide. So no - I cannot set my router to bridge mode.
I have disabled all WIFI on my modem and set DMZ to what my NG router gets from the modem.
So due to all these changes I really hope this kind of issue won't be seen again. I will be updating this topic in case it does.
Thank you everyone for the input!
Ok, Disabling of the WiFi on the modem and using it's DMZ for the XR router is going to be your best solution.
Enjoy. :smileywink:
