MorsMessor
Jan 30, 2020Aspirant
Xr500 Randomly Shuts off
It's been doing it a lot sometimes randomly and will happen twice no matter if I shut it off or not. It happens also when I start to stream which it will shut off twice.
Netduma_Alex
Jan 31, 2020NetDuma Partner
What do you mean by "shut off"?
Does the XR500 actually lose power or just drop internet?
When internet drops, are wired devices affected as well as wireless?
- MorsMessorFeb 07, 2020AspirantAll lights shut off/ turn orange tried to force it to happen to take a picture but I factory reset it recently and doesn't do it.
- Netduma-FraserFeb 08, 2020NetDuma PartnerSo since the reset the issue hasn't occurred? Let us know if it happens again please. If it does happen again directly connect to your ISP modem/router and see if that has a connection.
- MorsMessorFeb 08, 2020AspirantI've factory reset it 3x in about a week or so it will start acting up again. My modem is a cm700 and get 117 down and 15 up. Besides the awful wifi range that's the only problem. I tried to force the problem by streaming to take photos of my router and modem so you can see which slots have orange lights along with my modem. I don't believe it's the modem or the cable. Since with a Netgear ac1900 router it never has a problem.
- MorsMessorFeb 08, 2020AspirantIt's like when you reset your router through the Interface on your computer and wifi and all connected devices get disconnected.
- Netduma-FraserFeb 08, 2020NetDuma PartnerWhen you do a factory reset all devices will lose connection so that is normal. Is the router connected to a power extender? If so could you plug it directly into a wall outlet please and see if that helps. Also when the disconnections happen do you see any entries in the log around that time?
- MorsMessorFeb 09, 2020AspirantIt happened last night couldn't get a picture since my camera wouldn't turn the flash on and I haven't been able to see the log while it happens since it's at a random time everytime. It will randomly do it while I'm home the only device connected to it was my phone. I'll move it to the wall instead of the power supply. I've never had a router that just randomly shut off when ever it wanted to.
