MorsMessor
Jan 30, 2020Aspirant
Xr500 Randomly Shuts off
It's been doing it a lot sometimes randomly and will happen twice no matter if I shut it off or not. It happens also when I start to stream which it will shut off twice.
Netduma-Fraser
Feb 09, 2020NetDuma Partner
If you can provide some logs we may be able to determine the cause, it could be power fluctuations which is why I mentioned to use the wall outlet. Let us know when you can.
MorsMessor
Feb 13, 2020Aspirant
Plugged it into the wall Monday and hasn't shut off. But the wifi range is still abysmal. I'm not sure if it suppose to only work 30ft away or not but I'll have 2/4 bar signal but no internet.
