Endorphine71's avatar
Endorphine71
Apprentice
May 04, 2018
XR500 RApps Not Loading
Had a few questions for the NetDuma employees.  I posted a few weeks ago about the R-Apps not loading after setting up out of the box and doing the update to the current firmware.  I had to downgrade and go back to get them working again.
Since then I have had the router go down once, around 12am on May 1st.  I believe this may have been due to the traffic monitor I had setup.  Seems like when it reset the router froze up.  Did a reboot and all was good.  What I didn't realize at the time, is the same R-Apps, QoS and Geo-Filter were not working again.
I was looking at the logs that are generated, and notice a bunch of fatal errors with the DumaOS trying to bind specific services.  The geofilter and qos services were throwing all types of errors.  The only thing I had enabled myself on the router was IPv6 with autoconfig and a few static IP assignement to a few Nest Cams.
I attempted to reboot the router a few times to get the R-Apps working again, but still erroring out.  The only way I got things to work was to disable IPv6, and then the R-Apps registered and finally worked again.  This is frustrating, as I bought the router for the QoS feature, and will be using it all the time.  Any other reports of this issue?  I would call into Netgear support, but know I will need to be on the phone awhile an routed around.
[DumaOS] Ubus object 'com.netdumasoftware.geofilter' added, attempting to bind pending, Friday, May 04, 2018 10:11:51 [DumaOS] Ubus object 'com.netdumasoftware.geofilter' added, attempting to bind pending, Friday, May 04, 2018 10:11:51 [DumaOS] Ubus object 'com.netdumasoftware.geofilter' added, attempting to bind pending, Friday, May 04, 2018 10:11:51 [DumaOS] Ubus object 'com.netdumasoftware.geofilter' added, attempting to bind pending, Friday, May 04, 2018 10:11:51 [DumaOS] Ubus object 'com.netdumasoftware.geofilter' added, attempting to bind pending, Friday, May 04, 2018 10:11:51 [DumaOS] Ubus object 'com.netdumasoftware.geofilter' added, attempting to bind pending, Friday, May 04, 2018 10:11:51 [DumaOS] Ubus object 'com.netdumasoftware.geofilter' added, attempting to bind pending, Friday, May 04, 2018 10:11:51 [DumaOS] Ubus object 'com.netdumasoftware.geofilter' added, attempting to bind pending, Friday, May 04, 2018 10:11:51 [DumaOS] Ubus object 'com.netdumasoftware.devicemanager' now bound, Friday, May 04, 2018 10:11:51 [DumaOS] Ubus object 'com.netdumasoftware.geofilter' added, attempting to bind pending, Friday, May 04, 2018 10:11:52
[DumaOS] Ubus object 'com.netdumasoftware.geofilter' added, attempting to bind pending, Friday, May 04, 2018 10:12:04
[DumaOS] Ubus object 'com.netdumasoftware.qos' added, attempting to bind pending, Friday, May 04, 2018 10:12:23 [DumaOS] Ubus object 'com.netdumasoftware.devicemanager' now bound, Friday, May 04, 2018 10:12:23 [DumaOS] applying qos for zone wan, Friday, May 04, 2018 10:12:23 [DumaOS] applying qos for zone lan, Friday, May 04, 2018 10:12:23 [DumaOS] Ubus object 'com.netdumasoftware.geofilter' added, attempting to bind pending, Friday, May 04, 2018 10:12:23 [DumaOS] Ubus object 'com.netdumasoftware.qos' added, attempting to bind pending, Friday, May 04, 2018 10:12:23
[DumaOS] applying qos for zone wan, Friday, May 04, 2018 10:13:03 [DumaOS] applying qos for zone lan, Friday, May 04, 2018 10:13:04 [DumaOS] applying qos for zone wan, Friday, May 04, 2018 10:13:44 [DumaOS] applying qos for zone lan, Friday, May 04, 2018 10:13:44 [DumaOS] Marking device that is marked 192.168.1.130 46 16., Friday, May 04, 2018 10:13:45 [DumaOS] config write 'com.netdumsoftware.geofilter.settings', Friday, May 04, 2018 10:14:26 [DumaOS] config write 'com.netdumsoftware.geofilter.settings', Friday, May 04, 2018 10:14:26 [DumaOS] config write 'com.netdumsoftware.geofilter.settings', Friday, May 04, 2018 10:14:27
  • I haven’t heard anything specifically like that before, is it all working now? If not do a factory reset from the settings and that should fix it. It’s very rare for specific apps to have trouble loading - please keep us informed and if possible of specific reproducible steps
