s42's avatar
s42
Initiate
Dec 04, 2019
xr500 readyshare mac not working
Hello,
I've just plug a USB drive, the drive is displayed in the usb parameter activated everything... But when I try to connect through my mac to smb://readyshare it won't connect.
Thanks
  • s42's avatar
    s42
    Dec 05, 2019
    Hello,
    No need a screenshot just read the doc it doesn't support exFAT :( so I just format the drive to HFS and all is up and running well !
    Sorry for wasting your time
    Thanks
  • Could you post a screenshot of the ReadyShare settings you're using on the router please?
    • s42's avatar
      s42
      Initiate
      Hello,
      Thanks
