WacoJohn
Apr 05, 2025Luminary
XR500 Readyshare W11 Home
Works perfectly on 2 W10 Pro laptops. Not so on 1 W11 Home, Sorry to say I don't remember if it ever worked on W11 machine or not. Years ago .. b4 W11, Gearhead gave me some instructions which ha...
WacoJohn
Apr 07, 2025Luminary
smb1 is ON.
EXPLORER
\\readyshare\ReadyML or \\readyshare\ReadyNR
Windows can't access \\ready ........ Error 0x80004005
SUGGESTION:
Disconnect hard drives from router
Factory reset router (if I figure out how)
Bring it back up and connect the drives.
Only problem is there is something in there that needed to be changed from factory but don't remember what it was. Whatever it was was easy to do.
Netduma-Fraser
Apr 07, 2025NetDuma Partner
Perhaps the way W11 treats it is different, try:
\\192.168.1.1\ReadyML
instead and see if that works
