WacoJohn
Apr 05, 2025Luminary
XR500 Readyshare W11 Home
Works perfectly on 2 W10 Pro laptops. Not so on 1 W11 Home, Sorry to say I don't remember if it ever worked on W11 machine or not. Years ago .. b4 W11, Gearhead gave me some instructions which ha...
Apr 09, 2025Guru - Experienced User
Wondering if Win11 Home would be limiting vs Pro since Home doesn't have as many networking features and controls as Pro does.
WacoJohn
Apr 09, 2025Luminary
Fairly easy to find out. Back that W11 up and install W10 on it. I vaguely recall W11 working shortly after I upgraded from W10 to W11 but I can't be sure.
I will do the backup then put 10 on it and see. It will take me a good while though. Thank you again. I'll be back here.
- FURRYe38Apr 09, 2025Guru - Experienced User
If I can get some time, I'll get my XR500 out of the box and see if I can check this. I have Win11 Pro 24H2 on my machines here.
- WacoJohnApr 10, 2025Luminary
Confession: Have not tested with W10 (time constraints). What I did do was install W11 HOME .... but from scratch. Unfortunately, no change. I felt strongly W11 might have HAD a botched install. Apparently not though.
"I'll get my XR500 out of the box and see if I can check this. I have Win11 Pro 24H2 on my machines here."
Ya know, Sir. That would be terrific. I'm over loaded and though anxious to resolve this, ton of distractions right now. THANK YOU ..... at your convenience.- FURRYe38Apr 10, 2025Guru - Experienced User
Will give this a go this weekend. I too have lots of distractions as well. đ
I should have some time this weekend though.
