WacoJohn
Apr 05, 2025Luminary
XR500 Readyshare W11 Home
Works perfectly on 2 W10 Pro laptops. Not so on 1 W11 Home, Sorry to say I don't remember if it ever worked on W11 machine or not. Years ago .. b4 W11, Gearhead gave me some instructions which ha...
- Apr 12, 2025
First of all, it (W10 Pro) is working perfectly!!!!!!!!! I can't be sure exactly what was wrong or what fixed it. I did a sfc and Dism routine and it would not complete. Rebooted machine. Did an elevated Disk Cleanup. It would not complete. Did a CCLEANER PRO routine which completed. Rebooted machine. Dism/sfc again. They completed. Disk Cleanup again and it completed. Rebooted machine and it came up just right. Problem solved. Now have mapped M: and N: readyshare drives in Explorer. Backing that up now then on to W11 Pro. I expect it to work. Will see soon. đ
Of course thank you Sir .... for everything. Will come back to mark SOLVED once I see W11 Pro on that machine.
Apr 12, 2025Guru - Experienced User
Only other thing I didn't put in that PDF was enablement of SMBv1 Client which is enabled as well:
Ya, i've kept SMB v1 Client enabled on my PC for years. Haven't seen any issues with it to date.
WacoJohn
Apr 12, 2025Luminary
