WacoJohn
Apr 05, 2025Luminary
XR500 Readyshare W11 Home
Works perfectly on 2 W10 Pro laptops. Not so on 1 W11 Home, Sorry to say I don't remember if it ever worked on W11 machine or not. Years ago .. b4 W11, Gearhead gave me some instructions which ha...
Apr 15, 2025Guru - Experienced User
Just wanted to be sure. Thank you for the details on your troubleshooting.
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
- WacoJohnApr 15, 2025Luminary
no problem backing up xr500 cfg. I have maintained one for years and will create a new one to be sure. Can't be too sure but I think Disk Cleanup and CCleaner had a lot to do with (suddenly) fixing the problem. All is well that ends well, and thank you so much for everythng.
- FURRYe38Apr 15, 2025Guru - Experienced User
