WacoJohn
Apr 05, 2025Luminary
XR500 Readyshare W11 Home
Works perfectly on 2 W10 Pro laptops. Not so on 1 W11 Home, Sorry to say I don't remember if it ever worked on W11 machine or not. Years ago .. b4 W11, Gearhead gave me some instructions which ha...
WacoJohn
Apr 15, 2025Luminary
no problem backing up xr500 cfg. I have maintained one for years and will create a new one to be sure. Can't be too sure but I think Disk Cleanup and CCleaner had a lot to do with (suddenly) fixing the problem. All is well that ends well, and thank you so much for everythng.
Apr 15, 2025Guru - Experienced User
