LukeEyre01
Mar 02, 2021Tutor
XR500 Reboot
Hi, I have recently upgraded my internet package to a 600mbps package, ever since I have upgraded my netgear router constantly reboots. All the lights go orange and it then reboots back up to white. ...
Netduma-Fraser
Mar 02, 2021NetDuma Partner
Unplug the router fully from the power for 10 minutes to start with, then plug it in, does it continue to reboot? If so then remove the WAN/internet cable from it, does it still occur?
LukeEyre01
Mar 02, 2021Tutor
Hi,
I have tried leaving it unplugged for 10 mins, still no change. it doesn’t reboot when there is no internet cable plugged in.
- Netduma-FraserMar 02, 2021NetDuma PartnerCould you take the ISP router out of modem mode please, then reconnect it to the XR - does it continue to reboot then?
- LukeEyre01Mar 03, 2021TutorHi,
I have changed my isp modem/ router back to router mode and so far have had no crashes. But have noticed the WiFi speed is slower and speed test usually fail over WiFi. I have turned the WiFi off on the ISP as it is in router mode.- LukeEyre01Mar 03, 2021TutorThis is every time on the nighthawk app. Trying to test speed coming direct into the router
