LukeEyre01
Mar 02, 2021Tutor
XR500 Reboot
Hi, I have recently upgraded my internet package to a 600mbps package, ever since I have upgraded my netgear router constantly reboots. All the lights go orange and it then reboots back up to white. ...
LukeEyre01
Mar 02, 2021Tutor
Hi,
I have tried leaving it unplugged for 10 mins, still no change. it doesn’t reboot when there is no internet cable plugged in.
Netduma-Fraser
Mar 02, 2021NetDuma Partner
Could you take the ISP router out of modem mode please, then reconnect it to the XR - does it continue to reboot then?
- LukeEyre01Mar 03, 2021TutorHi,
I have changed my isp modem/ router back to router mode and so far have had no crashes. But have noticed the WiFi speed is slower and speed test usually fail over WiFi. I have turned the WiFi off on the ISP as it is in router mode.- LukeEyre01Mar 03, 2021TutorThis is every time on the nighthawk app. Trying to test speed coming direct into the router
- Netduma-LiamMar 03, 2021NetDuma Partner
OK thanks, how much slower are we talking? What are the before and after speeds?
