TayJBuiz
Apr 21, 2022Aspirant
XR500 Rebooting Itself After Attempts at Streaming and Downloading
As the title says, for some reason my new Netgear router is crashing non-stop whenever I attempt to use my WiFi to stream or download games for my console. I've had this device since last month and I...
Netduma-Liam
Apr 22, 2022NetDuma Partner
Could you please go to Settings -> Setup -> LAN setup and change the minimum DHCP pool address to 192.168.1.50.
Then add IP address reservations for each device on the network, make sure you give each device a different address between 192.168.1.2 and 192.168.1.49.
After that check if the problem still occurs.
- TayJBuizApr 22, 2022Aspirant
There's no "minimum". I have "Starting IP address" and "Ending IP address", then I also have IP Subnet Mask. I'm completely new to all of this.
- Netduma-FraserApr 22, 2022NetDuma PartnerEnter the starting IP as .50, then process with the reservations. Don't change anything else, you can leave subnet mask as it is. If you're unsure don't hesitate to ask!
Alright, I changed it but nothing happened. I think I should mention that my PS5 and smart TV are connected via wireless, not cable, as they're not within cabling range of my router.
