TayJBuiz
Apr 21, 2022Aspirant
XR500 Rebooting Itself After Attempts at Streaming and Downloading
As the title says, for some reason my new Netgear router is crashing non-stop whenever I attempt to use my WiFi to stream or download games for my console. I've had this device since last month and I...
Netduma-Liam
Apr 22, 2022NetDuma Partner
Could you please go to Settings -> Setup -> LAN setup and change the minimum DHCP pool address to 192.168.1.50.
Then add IP address reservations for each device on the network, make sure you give each device a different address between 192.168.1.2 and 192.168.1.49.
After that check if the problem still occurs.
TayJBuiz
Apr 22, 2022Aspirant
There's no "minimum". I have "Starting IP address" and "Ending IP address", then I also have IP Subnet Mask. I'm completely new to all of this.
