TWISM
Mar 15, 2018Guide
XR500 Rebooting
Hello,
I have an XR500 running 2.1.0.6. Over the past week I have noticed that randomly the router will reboot, during this time all wired/wireless connections drop and I can't access the router. It then comes back up and it works, it might work for a day, or it might reboot again 10 minutes later.
Has anyone else had that happen? I purchased this unit on Jan 9th and its just this past week I have been having issues with it. Nothign has changed in my enviroment in the past week.
- Netduma-FraserNetDuma PartnerHi TWISM,
I'll send you a PM, please continue to monitor the situation and see if that resolves the issue. - JasonNNETGEAR Employee Retired
Hi TWISM,
I just wanted to check in and see if your issue has been fixed.
Please let me know. :]
- Jason N
- TWISMGuide
No, it hasn't been fixed.
I will admit I called into support and it was a frustrating experience. I know they are there to help but I wish at times when you are not the average end user you were able to bypass all the basic tasks. I had to reset my router while they were on the phone, downgrade the firmware, detail to them what was on my network. They blamed everything but the router, it was a power issue, it was Amazon echo devices (how many and what model Amazon devices do you have).
Right now I am just dealing with a rebooting router until I have the time to call back in and go through the motions. I did downgrade, and reset and am just checking in to capture times when it reboots.
Hi TWISM,
Please do a factory reset on your XR500 device.
Hold the reset button located on the back of your device for 10-15 seconds. Next, Let the device boot all the way up.
Please let me know if this fixes your issue. :]
- Jason N
