Zelcor
Jul 23, 2019Aspirant
XR500 Reboots randomly
So I bought a new XR500 from Best Buy last month and there's been a strange consistent problem. It randomly reboots and then the internet doesn't work. If I reboot the router again the internet ...
Jul 24, 2019Guru - Experienced User
Zelcor wrote:So I bought a new XR500 from Best Buy last month and there's been a strange consistent problem.
If I reboot the router again the internet light still doesn't go back on and the connection is still broken.
If I reseat the network cable the internet is back.
So it goes like this.
Router reboots > all connection lights return online > internet light stays red > reseat the network cable.
And I'm back in business until it decides to reboot again.
I read some other posts and there maybe some kind of beta firmware I can download to get this resolved? Can anyone help me out?
Zelcor
Jul 24, 2019Aspirant
FURRYe38 wrote:What Firmware is currently loaded?
2.3.2.40
Arris SURFboard SB6183
I'm pretty sure it's set to auto. I'll give changing the channels a try.
Yes, quite a lot. But why would nearby wifi's force reboot my router and break the internet connection?
- FURRYe38Jul 24, 2019Guru - Experienced User
When the wifi is set to auto, the router will try to find a good clear channel to use, when the router encounters a noise channel, its trying to find a better channel. Since you say you have many other wifi neighbors near by, you maybe in a wifi congested area. This would be problematic.
- Netduma-FraserJul 24, 2019NetDuma PartnerPlease try this firmware, it's not specifically for your issue but it could help: https://forum.netduma.com/topic/28523-new-xr500-hotfix-firmware-for-drop-outs/
Do you have any consoles in a standby/instant on state at all?
