Zelcor
Jul 23, 2019Aspirant
XR500 Reboots randomly
So I bought a new XR500 from Best Buy last month and there's been a strange consistent problem. It randomly reboots and then the internet doesn't work. If I reboot the router again the internet ...
biancaj
Jul 25, 2019Guide
Unfortunately, I now have the same problem. I bought this router about a month or so ago and haven’t had any issues until two days ago. Magically, the router will reboot itself and not recognize the LAN/Ethernet/internet in port (light just stays red, even while the others are white again). I came across your thread by searching for the issue.
I tried the firmware update that was linked and it didn’t help. Additionally, the router logs magically get wiped after it decides to reboot, so I can’t even use the logs to figure out what’s causing the reboot.
I’m extremely disappointed (and honestly irate). I wasted $300 for a router that obviously doesn’t work.
- FURRYe38Jul 25, 2019Guru - Experienced User
What is the Mfr and model# of the ISP modem the NG router is connected too?Any Wifi Neighbors near by? If so, how many?
What devices do you have connected to the XR router?
Downgrade to v32 FW version please...Factory reset and then setup from scratch to see if the problem continues.
I’m extremely disappointed (and honestly irate). I wasted $300 for a router that obviously doesn’t work.- biancajJul 25, 2019GuideFirmware - 2.3.2.40-c424a, which was linked here as something that might resolve the problem.
ISP - Comcast
Modem - Motorola Arris SB6190
WiFi neighbors - yes? Not sure how many
Channels - auto
Devices - PS4/PC hardwired, iPhone/Mac/iPad wireless
How can I find the firmware you’re now suggesting?- Netduma_AlexJul 25, 2019NetDuma Partner
All of the old firmwares can be downloaded here: https://www.netgear.com/support/product/XR500.aspx
And the hotfix firmware is here: https://forum.netduma.com/topic/28523-new-xr500-hotfix-firmware-for-drop-outs/
