Zelcor
Jul 23, 2019Aspirant
XR500 Reboots randomly
So I bought a new XR500 from Best Buy last month and there's been a strange consistent problem. It randomly reboots and then the internet doesn't work. If I reboot the router again the internet ...
biancaj
Jul 26, 2019Guide
Well, my issue started up again today, so the firmware downgrade didn’t help.
Jul 26, 2019Guru - Experienced User
I would replace the router or ask NG support for an RMA...
- Netduma-FraserJul 27, 2019NetDuma PartnerAgree with the above, there shouldn't be anything to cause it to reboot so it may be a faulty unit.
- biancajJul 27, 2019GuideThank you (and thank you to furry as well). I exchanged it at Best Buy for a new one since I got their plan for it (it would’ve been under netgear’s warranty, but I game a lot and didn’t want to wait for a new one). It’s set up and running smoothly so far... I’ll report back (if this thread stays open) after a few weeks. I did notice a lot of people in the amazon reviews have also had this problem. I almost got a Netgear AX8 (can’t remember the exact number, but think it’s AX8) that has the new WiFi on it, but it didn’t have the geolocation/Duma features, so I stayed with the XR500. Thank you for being patient with me. I hope this one will be great for a long time. The guy at Best Buy said his buddy had the same thing happen (and that it also came from Best Buy about a month ago). Maybe it was a bad shipment?
- Netduma-FraserJul 27, 2019NetDuma PartnerYeah it might have been, thanks for the update, heres hoping it continues to work well!
