mondenath
Jun 20, 2018Prodigy
xr500 remote genie /nighthawk not working in mobile
The genie cant enable Remote management and even nighthawks says cant URL page not found.
Does this router wont support the remote app.
Netduma-Fraser
Jun 20, 2018NetDuma Partner
No I do not think it is supported as it's completely different to the usual software, there will be more support for these in future.
mondenath
Jun 20, 2018Prodigy
Then a mobile app which can do every thing and anything on the go is must for gaming. As adding port or enable anything or changing QOS on the fly will be ease with mobile app.
For now only Netgear Up/ nighthawk works locally.
Need this on remote app. Also the live network activity .
- Netduma-FraserJun 20, 2018NetDuma PartnerWe will be making an app in future for mobile that will allow the quick changes you're looking for
