Amiah's avatar
Amiah
Follower
Sep 08, 2024
Xr500 replacement Antennas for UK
Hi, I have been searching long and hard for some replacement XR500 Antenna 3's. Anyone know where I can get this from in the UK. tried to go via Netgear and ask them and they simply said check online....
  • Netduma-Fraser's avatar
    Sep 08, 2024
    I believe they are unscrewable/detachable rp-sma antennae and so there should be plenty of third party options of those that should work. I don't know if they even offer official antennae replacements.
