Toosmoothbooth
Nov 03, 2019Aspirant
Xr500 resets when TV turned on
Hello. I have noticed since the last update that when I turn my TV on which is connected to the router via WiFi it sometimes causes the router to reset. All the lights go off apart from the power whi...
Netduma-Fraser
Nov 03, 2019NetDuma Partner
Wow that's a weird one! Is the TV and the router connected to the same power extender by any chance?
- ToosmoothboothNov 03, 2019AspirantNope separate power outlets.
- Netduma-FraserNov 03, 2019NetDuma PartnerIn WAN Settings could you toggle IGMP Proxying please and see if that makes a difference? If not, could you check the network monitor and turn on the TV and see if you notice a massive spike in bandwidth at all? Same with looking at the logs, see if you notice an entry at the time you turn on the TV - may be easier to pin these panels to the dashboard so you can see them at the same time.
