Toosmoothbooth
Nov 03, 2019Aspirant
Xr500 resets when TV turned on
Hello. I have noticed since the last update that when I turn my TV on which is connected to the router via WiFi it sometimes causes the router to reset. All the lights go off apart from the power whi...
Toosmoothbooth
Nope separate power outlets.
Netduma-Fraser
Nov 03, 2019NetDuma Partner
In WAN Settings could you toggle IGMP Proxying please and see if that makes a difference? If not, could you check the network monitor and turn on the TV and see if you notice a massive spike in bandwidth at all? Same with looking at the logs, see if you notice an entry at the time you turn on the TV - may be easier to pin these panels to the dashboard so you can see them at the same time.
